> For the complete documentation index, see [llms.txt](https://docs.duplicati.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.duplicati.com/technical-details/understanding-restore/how-restore-works.md). Agents can also search and read this documentation through its [MCP server](https://docs.duplicati.com/~gitbook/mcp).
# How Restore Works
This page describes how the restore process works from a high level
The core restore process is from a high level perspective:
* Figure out what files should be restored
* For each file
  * Locate each block required
  * For each block
    * Locate the block volume
    * Download block volume
    * Decrypt and decompress block
    * Append block to file
  * After file is restored, verify the content matches the original
This description is a bit simplified, as it would be incredibly slow to execute in the basic form shown here. For a more developer oriented description, see the forum post on [how the restore process works](https://forum.duplicati.com/t/how-the-restore-process-works/17684).
The part about "figuring out what files should be restored" can be described in more parts:
* Find the full list of files in the version to restore from
* Apply filters to only restore the requested files
* Skip files that exists and contains the correct content
If there is a local database, many of the steps can be reduced to a database query, and for this reason, Duplicati will build a temporary database during restore, if there is not already a local database.
GET https://docs.duplicati.com/technical-details/understanding-restore/how-restore-works.md?ask=<question>&goal=<user_goal>
