For the complete documentation index, see llms.txt. This page is also available as Markdown.
SharePoint (legacy API)
This page describes the deprecated SharePoint storage destination that uses the legacy API
Duplicati supports using Microsoft SharePoint as a storage destination. This page describes the deprecated destination that uses the legacy SharePoint API (mssp://). For the current destination that uses the Microsoft Graph API, see SharePoint.
User interface
Configure Sharepoint destination
To configure the SharePoint destination, enter the values for: server, path on server, account name, and access key.
URL format for Commandline
To use SharePoint, use the following URL format:
Integrated Authentication (Windows only)
If you are on Windows, it may be possible to use the current user's credentials to authenticate. Support for this is depending on many details and is not available in all cases. To use integrated authentication, use the following URL format:
Advanced options
Instead of deleting files directly, they can be moved to the recycle bin by setting the option --delete-to-recycler. This gives some additional safety if a version removal was unintended, but is not generally recommended, as it is a manual process to recover from a partial delete.
The options --web-timeout and --chunk-size can be used to fine-tune performance that matches your setup, but generally it is recommended to keep them at their default values.
If you are running Duplicati in a data center with a very stable connection, you can use the option --binary-direct-mode to enable direct transfers for optimal performance.
Last updated
Was this helpful?
