Mega.nz Destination
This page describes the Mega.nz storage destination
User interface
To configure the Mega.nz backend, enter a unique path for the backup to be stored at, the username and password.
URL format for Commandline
To use the Mega.nz storage destination, you can use the following URL format:
Two-factor authorization
If the account has two-factor authentication enabled, provide the shared secret with the option --auth-two-factor-key. This is the Base32 string shown when two-factor authentication was set up on the account (the value behind the QR code), not the 6-digit code from the authenticator app. Duplicati uses the secret to compute the current TOTP code on each login, so the value does not change and is suitable for automated backups.
Last updated
Was this helpful?
