> For the complete documentation index, see [llms.txt](https://docs.duplicati.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.duplicati.com/backup-destinations/standard-based-destinations/s3-compatible-destination.md). Agents can also search and read this documentation through its [MCP server](https://docs.duplicati.com/~gitbook/mcp).
# S3-compatible Destination
This page describes the S3 storage destination
The Simple Storage Service, S3, was originally described, developed and offered by Amazon via AWS. Since then, numerous other providers have adopted the protocol and offer S3-compatible services. While these services are mostly compatible with the core S3 protocol, a number of additional AWS-specific settings are usually not supported and will be ignored.
This page deals with S3 in general, for a specific [setup on AWS S3, refer to the AWS specific page](https://docs.duplicati.com/backup-destinations/provider-specific-destinations/amazon-s3-destination.md).
When storing data in S3, the storage is divided into a top-level "folder" called a "bucket", and each bucket has "objects", similar to files. For most providers, an object name with `/`characters will be interpreted as subfolders in some way.
In the original S3 specification, the bucket name was used as part of the hostname, causing some issues with bucket names that are not valid hostnames, and some delays for new buckets caused by DNS update speeds. Newer solutions use a single shared hostname and provide the bucket name as a parameter.
For AWS S3, and most other providers, the bucket name is a global name, shared across all users. This means that simple names, such as `backup` or `data` will likely be taken, and attempts to use these will cause permission errors. For [AWS, the recommendation is to use a guid in the bucket name](https://docs.aws.amazon.com/AmazonS3/latest/userguide/bucketnamingrules.html#automatically-created-buckets) to make it unique. The Duplicati UI will recommend prefixing the account id to the bucket name, to make it unique.
<figure><picture><source srcset="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-13b73814c900c54d7815b4e3785b8ba747339977%2FScreenshot%202025-11-03%20at%2014.31.38.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-4ef95a9272efaea5ca88fb62c5896ee0b89eb9ba%2FScreenshot%202025-11-03%20at%2014.31.26.png?alt=media" alt="The S3 Backend Configuration view"></picture><figcaption></figcaption></figure>
To use the S3 backend you must fill in details for all the fields: bucket, folder path, server, AWS Access Key ID, and AWS Secret Access Key. Note that your provider may use different names for the different values, especially the Access Key Id and Secret Access Key may be called something like username and password.
With the advanced options you can choose many extra settings as described below.
In the new UI, you can pick a server from the list, or paste the endpoint or bucket URL from your provider into the server or bucket field. The server, bucket and folder are then filled in from the URL. Some providers, such as dosya, also have their own entry in the destination list, which fills in the server for you.
## URL format for Commandline
To use S3 as the storage destination, use a format such as:
s3://<bucket name>/<prefix>
  ?aws-access-key-id=<account id or username>
  &aws-secret-access-key=<account key or password>
  &s3-server-name=<server ip or hostname>
  &use-ssl=true
Note that the default for S3 is to use unencrypted connections. The connections are secured with signatures, but all data transferred can be captured through the network. If the provider supports SSL/TLS, which most do, make sure to add `--use-ssl=true`to also encrypt the connection.
Make sure you consult the provider documentation to get the server name you need for the bucket region. If you are using AWS, [see the AWS S3 description](https://docs.duplicati.com/backup-destinations/provider-specific-destinations/amazon-s3-destination.md).
## Choosing the client
The S3 storage destination can either use the [AWS S3 library](https://docs.aws.amazon.com/sdk-for-net/v3/developer-guide/csharp_s3_code_examples.html) or [Minio library](https://min.io/docs/minio/linux/developers/dotnet/minio-dotnet.html), and you can choose the library to use with `--s3-client=minio`.
Generally, both libraries will work with most providers, but the AWS library has some defaults that may not be compatible with other providers. While you can configure the settings, it may be simpler to use Minio with the default settings.
## Using non-AWS storage
Most providers other than AWS S3 use an older version of the protocol, so to connect to them you often need to set either the option `--s3-disable-chunk-encoding` or use the Minio client with `--s3-client=minio` (but not both):
<figure><picture><source srcset="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-4a5a7b95087708e26e82192df84a427998941db0%2FScreenshot%202025-11-03%20at%2014.36.22.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-f9f7617250f2ac2acc71db20f0520e70b8b35406%2FScreenshot%202025-11-03%20at%2014.36.28.png?alt=media" alt="Advanced options picked for compatibility with non-AWS storage"></picture><figcaption></figcaption></figure>
Other options that can help with some providers:
* `--s3-disable-payload-signing` disables payload signing, which is not supported by all providers. This only applies to the AWS client.
* `--s3-authentication-region` sets the region used when signing requests. If it is not set, the region from `--s3-location-constraint` is used. This option is available from Duplicati 2.3.0.0.
* `--s3-recursive-list` lists all objects below the folder path, including objects in subfolders. By default, only the objects directly in the folder path are listed.
The AWS client also accepts the settings of the AWS library with the prefix `--s3-ext-`, for instance `--s3-ext-forcepathstyle=true`. Run `duplicati-cli help s3` to see the full list. For servers that do not end with `.amazonaws.com`, Duplicati sets `--s3-ext-forcepathstyle=true` unless you set it yourself.
## Creating the bucket
Since the bucket defines the place where data is stored, a bucket needs to be created before it can be used. All providers will offer a way to do this through their UI, and allows you to set various options, such as which geographical region the bucket is located in.
If you use Duplicati to create the bucket, you can also set the option `--s3-location-constraint`to provide the desired location. Support for this, and available regions, depends on the provider.
## Storage class
With S3 it is also possible to set the storage class which is sometimes used to fine-tune the cost/performance/durability of the files. The storage class is set with `--s3-storage-class`, but the possible settings depends on the provider.
## List API version
Duplicati lists the files in the bucket with the S3 ListObjects API. Some S3-compatible providers have problems with this API, but work with the newer ListObjectsV2 API. If listing the files fails with your provider, you can switch to ListObjectsV2 with the option `--s3-list-api-version=v2`. The possible values are `v1` and `v2`, and the default is `v1`. This option applies to the AWS client, which is the default client. This option is available from Duplicati 2.4.1.0.
## Server-side encryption
Duplicati encrypts the volumes itself before uploading them. In addition, you can ask the server to encrypt the files it stores with `--s3-server-side-encryption`, which sends the `x-amz-server-side-encryption` header with each upload:
* `AES256` uses keys managed by the server.
* `aws:kms` uses keys managed by the key management service. Choose the key by its id, alias or ARN with `--s3-server-side-encryption-kms-key-id`; without it, the default key of the account is used.
If the option is not set, the server applies the default encryption of the bucket, if any.
## Assuming an IAM role
Instead of giving the access key direct access to the bucket, you can let Duplicati reach the bucket through an IAM role with temporary credentials from STS. Give the role with `--s3-assume-role-arn`, such as `arn:aws:iam::123456789012:role/backup`. The access key is then only used to assume the role, and the requests are signed with the temporary credentials of the role, which are renewed before they expire.
These options adjust how the role is assumed:
* `--s3-assume-role-session-name` names the session, which shows in the AWS logs.
* `--s3-assume-role-external-id` gives the external id that the trust policy of the role requires.
* `--s3-sts-endpoint` uses another STS endpoint than the one of AWS, such as the one of a MinIO server, given as a URL. Without it, the global AWS endpoint is used, or the one of the authentication region.
Assuming a role is only supported by the AWS client, so it cannot be combined with `--s3-client=minio`.
GET https://docs.duplicati.com/backup-destinations/standard-based-destinations/s3-compatible-destination.md?ask=<question>&goal=<user_goal>
