> For the complete documentation index, see [llms.txt](https://docs.duplicati.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.duplicati.com/backup-destinations/decentralized-providers/storj-destination.md).
# Storj Destination
This page describes the Storj storage destination
Duplicati supports backups to the [Storj network](https://www.storj.io) which is a large-scale decentralized storage network. The destination supports two different ways of authenticating: Access Grant and Satellite API.
<figure><picture><source srcset="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-759f9edb64efbbda3b02d31e2cb583c18bec516d%2FScreenshot%202025-11-03%20at%2016.50.48.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-2bbecc2915b1462f6332e60b5378d7ed3c5a22ab%2FScreenshot%202025-11-03%20at%2016.50.39.png?alt=media" alt="Configure the Storj destination"></picture><figcaption></figcaption></figure>
To configure the Storj destination, choose the satellite that you will connect to, then provide the access grant. The bucket and path can be used to control where the data is stored within the network.
## URL format for Commandline
### Access Grant
To use the access grant method, use the following URL format:
storj://
  ?storj-auth-method=Access%20Grant
  &storj-shared-access=<access key>
### Satellite API
To use a satellite API, use the following URL format:
stor://
  ?storj-satellite=<hostname:port>
  &storj-api-key=<api key>
  &storj-secret=<secret>
If the `--storj-satellite` is omitted it will default to a US based endpoint.
## Bucket and folder
To choose the bucket where data is stored, use the `--storj-bucket` which will default to `duplicati`. If further differentiation is needed, use `--storj-folder` to specify a folder within the bucket where data is stored.
GET https://docs.duplicati.com/backup-destinations/decentralized-providers/storj-destination.md?ask=<question>&goal=<user_goal>
