> For the complete documentation index, see [llms.txt](https://docs.duplicati.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.duplicati.com/backup-destinations/standard-based-destinations/openstack-destination.md). Agents can also search and read this documentation through its [MCP server](https://docs.duplicati.com/~gitbook/mcp).
# OpenStack Destination
This page describes the OpenStack storage destination
Duplicati supports storing files with OpenStack, which is a large-scale object storage, similar to S3. With OpenStack you store "objects" (similar to files) in "containers" which define various properties shared between the objects. If you use a `/` in the object prefix, they can be displayed as virtual folders when listing them.
<figure><picture><source srcset="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-8b7f496a6912f3f2d664e79972fd3c005fdf9389%2FScreenshot%202025-11-03%20at%2015.00.28.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-3714be5c6e2afec15a35fdacc2fb1c6de8499da2%2FScreenshot%202025-11-03%20at%2015.00.39.png?alt=media" alt="View of the OpenStack destination configuration"></picture><figcaption></figcaption></figure>
To use the OpenStack destination you must fill out the fields: bucket, domain name, tenant name, auth uri, version and region.
Note that the Bucket is sometimes called Container. The version of the protocol depends on your provider. See below for details. Depending on your connection you will need to also add some advanced options to specify an API key or a password.
## URL format for Commandline
### OpenStack v2
If you are using OpenStack with version 2 of the protocol, you can either use an API key or a username/password/tenant combination. To use the password based authentication, use a URL format like this:
openstack://<container>/<prefix>
  ?auth-username=<username>
  &auth-password=<password>
  &openstack-tenant-name=<tenant>
  &openstack-authuri=<url to auth endpoint>
If you are using an API key, leave out the `--auth-password` and `--openstack-tenant-name` parameters and add in `--openstack-apikey=<apikey>`.
### OpenStack v3
If you are using OpenStack with version 3 of the protocol, you must supply: username, password, domain, and tenant name:
  &openstack-domain-name=<domain>
  &openstack-authuri=<url to keystone server>
  &openstack-version=v3
## Region selection
The authentication response will contain a set of endpoints to be used for actual transfers. In some cases, this response can contain multiple possible endpoints, each with a different region. To prefer a specific region, supply this with `--openstack-region`. If any of the returned endpoints have the same region (case-insensitive compare), the first endpoint matching will be selected. If no region is specified, or no region matches, the first region in the response is used.
GET https://docs.duplicati.com/backup-destinations/standard-based-destinations/openstack-destination.md?ask=<question>&goal=<user_goal>
