> For the complete documentation index, see [llms.txt](https://docs.duplicati.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.duplicati.com/technical-details/understanding-backup/encryption-algorithms.md). Agents can also search and read this documentation through its [MCP server](https://docs.duplicati.com/~gitbook/mcp).
# Encryption Algorithms
This page describes how Duplicati handles encryption
The modular design in Duplicati makes it simple to add new encryption methods, if needed. By default, Duplicati ships with a built-in [AES](https://en.wikipedia.org/wiki/Advanced_Encryption_Standard)-based encryption and a [GPG](https://en.wikipedia.org/wiki/GNU_Privacy_Guard)-based encryption that requires GPG binaries to be present on the system.
## AES Encryption
The built-in [AES encryption is an open-source C# port](https://github.com/duplicati/sharpaescrypt) of the open-specification [AESCrypt file format](https://www.aescrypt.com). The file format ensures that each volume is encrypted with a separate random file-encryption key (FEK), which makes it harder to perform analysis on the encrypted volumes. The file format also adds a [HMAC](https://en.wikipedia.org/wiki/HMAC) signature that prevents modifications to the encrypted volume.
### AES Crypt format versions
Duplicati 2.4 can write two versions of the AES Crypt format. Version 2 is the format used by all earlier versions. Version 3 uses a stronger key derivation with a configurable number of iterations (`--aes-v3-iterations`, default `300000`).
Duplicati 2.4 still writes version 2 unless `--aes-version=3` is set (before Duplicati 2.4.1.0, the `duplicati-cli help aes` output lists `3` as the default, but version 2 is what is written). Volumes in version 3 can only be read by Duplicati 2.4 and later (and the 2.3.1 beta), so do not switch to version 3 if the backup must remain readable by older versions, for instance for a downgrade. Duplicati reads both versions regardless of the setting, so existing volumes keep working after a change.
The option `--aes-minimal-header` leaves out the optional metadata (creator, timestamp) from the file header.
## GPG Encryption
With GPG encryption the implementation requires the GPG binaries to be installed on the system. GPG is available on most Linux distributions, and in most package managers, but can otherwise be obtained via the [GnuPG download page](https://www.gnupg.org/download/).
By default, GPG encryption is done with symmetric encryption and default options ([CAST-128](https://en.wikipedia.org/wiki/CAST-128)), using the provided passphrase. It is possible to supply custom arguments to GPG, to choose a different algorithm, or even set it up to perform asymmetric encryption where only the public key is present on the client.
From canary 2.4.1.103, two options make the common cases easier, without writing the GPG arguments yourself:
* `--gpg-encryption-recipient` encrypts the volumes to the public key of a user ID, key ID or fingerprint, by passing `--recipient` and `--encrypt` to GPG instead of `--symmetric`. The key must be in the GPG keyring of the user Duplicati runs as, and be trusted. Only the matching private key can decrypt the files, and the passphrase is then used to unlock the private key. A command given in `--gpg-encryption-command` takes precedence.
* `--gpg-encryption-cipher-algo` chooses the cipher GPG encrypts with, such as `AES256`, by passing `--cipher-algo` to GPG. If not set, GPG uses its own default. Decryption does not need it, as GPG reads the cipher from the file. A `--cipher-algo` given in `--gpg-encryption-switches` takes precedence.
For example, to encrypt with AES-256 to a public key:
--encryption-module=gpg --gpg-encryption-recipient=backup@example.com --gpg-encryption-cipher-algo=AES256
{% hint style="warning" %}
With `--gpg-encryption-recipient`, restoring, verifying, repairing and compacting the backup all need the private key. Keep a copy of the private key in a safe place apart from the machine, as the backup cannot be read without it.
{% endhint %}
GET https://docs.duplicati.com/technical-details/understanding-backup/encryption-algorithms.md?ask=<question>&goal=<user_goal>
