For the complete documentation index, see llms.txt. This page is also available as Markdown.
Upgrading and downgrading
This page describes how to downgrade Duplicati from a newer version to an older version
Upgrading
To upgrade Duplicati, install the new version over the existing one. You do not need to uninstall the previous version first:
  • Windows: run the new MSI package. It replaces the installed version and keeps the installation folder.
  • Linux: install the new .deb or .rpm package in the same way as the first installation.
  • MacOS: open the new .dmg file and replace the application, or run the new .pkg installer.
Duplicati does not delete your configurations or backup databases when it is upgraded or uninstalled, so your settings and jobs will remain intact.
The server regularly checks for new versions and shows "New update found" in the user interface when one is available. You can also check from the "About Duplicati" page with "Check for updates", and download a new version from the "Download update" link on the same page. From the commandline, the AutoUpdater can check for a new version with duplicati-autoupdater check and download the package that matches your system with duplicati-autoupdater download.
When Duplicati starts and discovers an older version of its configuration, it will automatically update the configuration and databases to the new version.
Installing new versions of Duplicati is part of the test process so any upgrade is intended to keep things working the same as before. In some cases the updates will start to give a warning on backups that were previously running without a warning. These warnings will describe what has changed and explain what to do to remove the warning.
Such warnings generally relate to a feature that will be removed or renamed but is not yet removed. The warnings give you a heads-up to avoid issues in the future and are generally simple to implement by editing a backup.
In rare cases a feature can no longer be supported, such as when a storage provider stops offering a service. For these, the feature will be removed and this will be mentioned in the release notes.
Downgrading
Downgrades are usually not supported automatically because the old version was created before the current version; the code inside the old version cannot know what was changed. To avoid data loss, this process is controlled by version numbers inside the database. If you want to downgrade, you must use the DatabaseTool manually before installing the older version.
Each update to the data will increment the version number of the database such that when an older version is running it will detect a higher number than it knows and stop there.
When a version upgrades the database, it will create a backup of the current database before upgrading. You can look for the database and backups in:
  • ~/.config/Duplicati on Linux
  • ~/Library/Application Support/Duplicati on MacOS
  • %LOCALAPPDATA%\Duplicati on Windows.
If you have been using the new version you may have changes in the current database that would be lost by restoring the pre-upgrade database. In that case, you can ask on the forum for advice on how to downgrade.
Last updated
Was this helpful?
