> For the complete documentation index, see [llms.txt](https://docs.duplicati.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.duplicati.com/backup-destinations/standard-based-destinations/sftp-ssh-destination.md).
# SFTP (SSH) Destination
This page describes the SFTP (SSH) storage destination
The SFTP destination is using the ubiquitous SSH system to implement a secure file transfer service. Using SSH allows secure logins with keys and is generally a secure way to connect to another system. The SSH connection is implemented with [Renci SSH.Net](https://github.com/sshnet/SSH.NET).
<figure><picture><source srcset="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-18cb313e7b85dd8d54d864c12f0efa87cd5b3d01%2FScreenshot%202025-11-03%20at%2014.44.44.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-7ca69143ed125098aa9626727bc86efaf0ec4ede%2FScreenshot%202025-11-03%20at%2014.44.52.png?alt=media" alt="View of the SSH connection configuration screen"></picture><figcaption></figcaption></figure>
To use the SFTP destination you must enter at least the shown information: server, port, folder path, and username. You must most likely also provide either a password or an SSH private key through the advanced options.
## URL format for Commandline
To use the SFTP destination you can use a URL such as:
ssh://<hostname>/<path>
  ?auth-username=<username>
  &auth-password=<password>
  &ssh-fingerprint=<fingerprint>
You can supply a non-standard port through the hostname, such as `ssh://hostname:2222/folder`.
The path is an absolute path on the server, so `ssh://hostname/backup` uses the folder `/backup`. If you do not know the full path, set `--ssh-relative-path` to treat the path as relative to the folder the server starts in after login, usually the home folder of the user. This requires that the server reports that starting folder as an absolute path.
## Using key-based authentication
It is very common, and more secure, to use key-based authentication, and Duplicati supports this as well. You can either provide the entire key as part of the URL or give a path to the key file. If the key is encrypted, you can supply the encryption key with `--auth-password`.
Starting with Duplicati 2.2 it is now possible to provide an SSH private key file with the option `--ssh-keyfile=/path/to/file` or an inline key with the option `--ssh-key=url-encoded-key` . In the user interface you can drop the file with the private key, or paste in the contents.
<figure><picture><source srcset="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-1858b12c9bf369b21b2c704d87ebbcf9e19d016e%2FScreenshot%202025-11-03%20at%2014.45.32.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-9514ea2d436499be718c4cf82c43b2274ce6aa09%2FScreenshot%202025-11-03%20at%2014.45.25.png?alt=media" alt="Advanced options shown for the SFTP backend"></picture><figcaption></figcaption></figure>
## Using key-based authentication from the Commandline
To use a private key inline, you need to url encode it first and then pass it to `--ssh-key`. An example with an inline private key:
ssh://server/home/backup
  ?ssh-key=sshkey%3A%2F%2F----%20BEGIN%20SSH2%20PRIVATE%20KEY%20----...
  &auth-username=user
Note that you need both the prefix `sshkey://` and you need to URL encode the contents.
If you have the SSH keyfile installed in your home folder, you can use the file directly with `--ssh-keyfile`:
  ?ssh-keyfile=/home/user/.ssh/keyfile
  &auth-username=user
  &auth-password=<keyfile password>
If the key file is encrypted, the password must be passed as shown. Duplicati can also authenticate through a running `ssh-agent`: if neither a password nor a key is supplied, the agent is used automatically. Set `--ssh-disable-agent=true` to prevent this. On MacOS, the keychain is queried for the private key passphrase as well.
For best security it is recommended to use a separate identity and key files for the user, so a compromise of the keys does not grant more permissions than what is required.
## Validating the host key
Since SSH does not have a global key registry, like for HTTPS, it is possible to launch a man-in-the-middle attack on an SSH connection. To prevent this, Duplicati and other SSH clients will use certificate pinning where the previously recorded host certificate hash is saved and changes to the host certificate must be manually handled by the user.
On the first connection to the SSH server, Duplicati will throw an exception that explains how to trust the server host key, including the host key fingerprint. Once you obtain the host key fingerprint, you can supply it with the `--ssh-fingerprint` option.
If the host key changes, you will get a different message, but also reporting the new host key, so you can update it. The option `--ssh-accept-any-fingerprints=true` is only recommended for testing and not for production setups as it will disable the man-in-the-middle protection.
If you are using the UI, you can click the "Test now" button and it will guide you to set the host key parameters based on what the server reports. From canary 2.4.1.103, the UI also asks you to approve an unknown host key before browsing the folders of the SFTP server, so the folder picker works on the first connection. If the host key has changed since it was approved, the UI warns about it, and you should check with the server administrator before approving the new key.
## Timeout and keep-alive
By default, Duplicati will assume that the connection works once it has been established. If the SSH server is malfunctioning it may cause operations to hang. To guard against this case, the generic timeout options apply to the SFTP destination: `--read-write-timeout` (default `30s`) raises an error if no data is transferred within the interval, `--list-timeout` (default `10m`) limits directory listings, and `--short-timeout` (default `30s`) limits short operations such as delete and create folder. The older `--ssh-operation-timeout` option is deprecated in favor of these.
A different kind of timeout is when firewalls and other network equipment monitors the connections and closes them if there is no activity. Because Duplicati may open a connection and then perform a long operation locally, it may cause the connection to be closed due to inactivity. The option `--ssh-keepalive` can be used to define a keep-alive interval where messages are sent if there is no other activity.
The keep-alive is default disabled and should only be enabled if there are special conditions in a setup where it is needed.
GET https://docs.duplicati.com/backup-destinations/standard-based-destinations/sftp-ssh-destination.md?ask=<question>&goal=<user_goal>
