> For the complete documentation index, see [llms.txt](https://docs.duplicati.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.duplicati.com/backup-destinations/decentralized-providers/sia-destination.md).
# Sia Destination
This page describes the Sia storage destination
{% hint style="danger" %}
The Sia destination has been **removed**, as the implementation was not compatible with the hard-fork of the Sia network (canary 2.1.0.119, first stable release without it: 2.2.0.0). The `sia://` URL is no longer recognized. This page is kept for reference only.
{% endhint %}
Duplicati supports backups to the [Sia network](https://sia.tech) which is a large-scale decentralized storage network. To use the Sia destination, use this URL format:
sia://<host>:<port>/<path>
  ?sia-password=<password>
If the host is supporting unauthenticated connections, you can omit the password. The default port is `9980` if none is supplied and the default path is `/backup` if none is supplied.
## Advanced options
To adjust the amount of redundancy in the Sia network, use the option `--sia-redundancy`. Note that this value should be more than `1`.
GET https://docs.duplicati.com/backup-destinations/decentralized-providers/sia-destination.md?ask=<question>&goal=<user_goal>
