Downgrade from 2.4 to 2.3
This page describes how to downgrade from Duplicati 2.4 to 2.3
Duplicati 2.4 updated the server database to version 12. Duplicati 2.3 expects server version 11 and will not start with a database that has a newer version. The local databases are version 19 in Duplicati 2.4.0.x and 2.3, but Duplicati 2.4.1.0 updated them to version 22. See Database versions for an overview.
Remove sync jobs
Version 12 of the server database records whether a job is a backup or a sync job. Duplicati 2.3 does not support sync jobs, and the downgrade removes this information, so any sync job would afterwards be treated as a regular backup. Delete any sync jobs before downgrading.
Downgrade the databases
Make sure Duplicati is not running, and then use the DatabaseTool to downgrade the databases:
duplicati-database-tool downgrade --server-version=11 --local-version=19The --local-version=19 part downgrades local databases from Duplicati 2.4.1.0 or newer, and leaves local databases from 2.4.0.x unchanged. Sync databases are not used by Duplicati 2.3, so they do not need to be downgraded.
After the downgrade is complete, uninstall Duplicati 2.4 and install 2.3.
Obtaining older releases
The installer packages for 2.3.0.4 are available on Github. You can browse the list of releases for other versions you may want.
Last updated
Was this helpful?
