Downgrade from 2.3 to 2.2
This page describes how to downgrade from Duplicati 2.3 to 2.2
Duplicati 2.3 updated the server database to version 11 and the local databases to version 19. Duplicati 2.2 expects server version 9 and local version 17, and will not start with a database that has a newer version. See Database versions for an overview.
Remove the database encryption
Starting with 2.3, if no --settings-encryption-key is provided, Duplicati encrypts the server database with a random key that is stored in the operating system's secret store (Windows Credential Manager, MacOS Keychain, or libsecret/pass on Linux). Duplicati 2.2 does not read the key from there, so it cannot open the encrypted fields.
If you have not provided your own encryption key, stop all running instances and start the Server or TrayIcon once with:
duplicati-server --disable-db-encryption=trueThis removes the field-level encryption from the server database. Stop Duplicati again before continuing.
If you provide your own key with --settings-encryption-key or the SETTINGS_ENCRYPTION_KEY environment variable, you can skip this step, as long as you also provide the same key to Duplicati 2.2.
Downgrade the databases
Make sure Duplicati is not running, and then use the DatabaseTool to downgrade the server database and all local databases:
duplicati-database-tool downgrade --server-version=9 --local-version=17After the downgrade is complete, uninstall Duplicati 2.3 and install 2.2.
Obtaining older releases
The installer packages for 2.2.0.3 are available on Github. You can browse the list of releases for other versions you may want.
Last updated
Was this helpful?
