For the complete documentation index, see llms.txt. This page is also available as Markdown.
Duplicati Storage configuration
This page describes how to configure Duplicati Storage, including the storage region, object locking for the organization and for each machine, and how to migrate existing storage to a bucket with obj
Duplicati Storage works without any configuration, but the Duplicati Console has a few settings that control where the data is stored and how it is protected. The settings are found in the Duplicati Console under Settings → Storage, and cover:
  • The default region, which decides where the data for new machines is stored.
  • The default object lock, which makes uploaded backup files immutable for a period of time.
  • Per-machine object lock settings, which override the organization defaults for a single machine.
  • Bucket migration, which moves the storage for a machine to a new bucket with object locking.
The storage settings at the top of the Storage page
How the storage is organized
Each machine that uses Duplicati Storage has its own storage container, called a bucket. The bucket is created the first time the machine stores data, and it is created in the region and with the object lock settings that are in effect for the machine at that time. All backups made by the machine are stored in the same bucket, separated by the backup ID.
This is important to understand when changing the settings, as some properties of a bucket can only be chosen when the bucket is created:
Setting
New machines
Machines that already store data
Region
Uses the new setting
Stays in the region the bucket was created in
Object lock on or off
Unchanged, the bucket must be migrated to add it
Retention mode and period
Updated right away, if the bucket already has object lock
Default region
The Default region selects where the data is stored for machines that start using Duplicati Storage. The list has the following types of entries:
  • Auto (Nearest) picks the data center closest to the machine when the machine makes the first backup. This is the default.
  • A region, such as EU (nearest), USA (nearest) or Asia (nearest), picks the nearest data center within that area. Use this when the data must stay within an area, for instance for compliance reasons, but the exact location is not important.
  • A specific data center, grouped by area and shown with the country flag. Use this when the data must be stored in a specific location.
The region picker with areas and data centers
A data center marked with an info icon is currently not available for new backups. Machines that already store data in it are not affected.
The region of each machine is shown next to the machine name in the machine list. Changing the default region does not move existing data.
Object lock
Object lock, also known as WORM (Write Once, Read Many), makes the uploaded backup files immutable for a retention period. While a file is locked, it cannot be deleted or overwritten by anyone using the storage API key, so the backups are protected even if the machine, or the credentials it uses, are compromised.
Object lock also keeps the previous versions of files that are deleted or overwritten, which makes it possible to restore from a point in time if the backup files are damaged.
Object lock is applied by the storage itself, not by Duplicati. Neither the machine, the Duplicati Console nor Duplicati support can unlock a file before the retention period has expired.
Organization settings
The current setting is shown on the Storage page under Default object lock, either as Enabled with a summary such as Governance · 30 days default retention, or as Disabled. Click Change to edit the settings.
The Default object lock dialog
The dialog has the following settings:
Setting
Description
Object lock
Enabled or Disabled. When enabled, new buckets are created with object lock.
Retention mode
Governance (default) or Compliance. See Retention modes below.
Default retention
No default retention, or Fixed number of days. With a fixed number of days, every uploaded file is locked for that many days. The number of days must be a whole number greater than zero.
The retention mode and default retention are only shown when object lock is enabled.
When the settings are saved, they are used for all new buckets, and the retention mode and default retention of existing buckets that already have object lock are updated to match. Machines with their own machine settings keep the values they override.
Retention modes
Mode
Description
Governance
Locked files cannot be deleted or overwritten with the storage API key. Privileged users at the storage provider can lift the lock. This is the default, and is recommended to start with.
Compliance
Locked files cannot be deleted or overwritten by anyone, including Duplicati, until the retention period has expired. The lock period cannot be shortened.
The Duplicati Console does not currently offer a way to lift a governance lock, so for both modes, locked files stay in the storage until the lock expires. Additional controls for removing files with governance lock will be added in a future update.
Default retention
With a default retention, the storage locks every new file for the configured number of days as soon as it is uploaded. No changes are needed on the machine, as the lock is applied by the storage.
With No default retention, object lock is available, but files are only locked when the Duplicati client asks for it. To do this, add the --remote-file-lock-duration option to the backup, as described in Using remote file locking. This makes it possible to use a different lock period for each backup.
Choose a retention period that is shorter than the period Duplicati keeps the backup versions for. When Duplicati deletes an old backup version or compacts the backup, the files it removes stay in the storage until their lock expires, and the storage they use counts towards the quota until then.
Storage usage with object lock
When object lock is enabled, a file that is deleted or overwritten is not removed right away. The storage keeps the previous version, which is what makes point-in-time restore possible, and removes it with a daily cleanup once it is no longer locked:
  • A file that is not locked is removed within about 24 hours after it was deleted.
  • A file that is locked is removed within about 24 hours after the lock expires.
Until then, the storage used by the file is still counted in the storage usage and towards the quota. The dialog shows a warning about this when object lock is enabled.
Disabling object lock
Object lock cannot be removed from a bucket once it is enabled. When object lock is disabled for the organization or a machine:
  • New buckets are created without object lock.
  • The default retention is removed from existing buckets, so new uploads are no longer locked automatically.
  • Files that are already locked stay locked until their retention expires.
  • Earlier versions of deleted files are still kept and cleaned up as described above.
Machine settings
Each machine can override the organization settings. In the machine list on the Storage page, open the actions menu for the machine and choose Object lock settings.
The object lock dialog for a machine
The dialog has the same settings as for the organization, but each setting also has the option Inherit from organization, which shows the current organization value in parentheses. An inherited setting follows the organization setting if it is changed later. Choose a specific value to override it for the machine.
The machine settings can be used to, for instance:
  • Enable object lock only for the machines that need it, while keeping it disabled for the organization.
  • Use compliance mode, or a longer retention, for a machine with critical data.
  • Use No default retention for a machine where the lock period is set per backup with --remote-file-lock-duration.
When the machine settings are saved, the bucket for the machine is updated right away, if it already has object lock. If object lock is enabled for a machine whose bucket was created without it, the bucket must be migrated.
Object lock status for a machine
The machine list shows the object lock status next to each machine name. Hover over the status to see the details, including whether the settings come from the organization or from a machine override.
The object lock status and its tooltip in the machine list
Status
Description
Governance / Compliance
Object lock is enabled for the storage of the machine, with the retention mode shown.
Not locked
Object lock is not enabled for the machine.
Object lock not applied
Object lock is enabled in the settings, but the bucket for the machine was created without it. Migrate the bucket to apply it.
Migrating bucket
A bucket migration is running for the machine. Backups and restores on the machine fail until it completes.
Migrate a bucket to object lock
Object lock can only be enabled when a bucket is created. For a machine that already stores data in a bucket without object lock, the storage must be moved to a new bucket. The Duplicati Console does this with a bucket migration.
The option is available when the machine shows Object lock not applied. To start a migration:
  1. Make sure object lock is enabled for the machine, either through the organization settings or the machine settings, and that the retention mode and default retention are as intended.
  2. Open the actions menu for the machine and choose Migrate bucket to object lock.
  3. Read the confirmation dialog, and click Migrate bucket.
The confirmation dialog for a bucket migration
The migration runs in the background with the following steps:
  1. The storage API keys for the machine are revoked, so nothing is written to the storage while the migration runs.
  2. A new bucket is created with the object lock settings for the machine.
  3. Every file is copied to the new bucket, and the copy is verified.
  4. The default retention is applied to the new bucket, and the machine is switched to it.
  5. The old bucket is deleted.
When the migration has completed, the machine receives new credentials for the new bucket the next time it connects to the storage, and the backups continue as before. No changes are needed in the backup configuration.
Follow the migration
While the migration runs, the machine shows the status Migrating bucket. To see the progress, open the actions menu for the machine and choose Bucket migration status.
The bucket migration status dialog
The dialog shows the number of files and bytes copied, the names of the old and the new bucket, and when the migration started and finished. The migration goes through the following states:
State
Description
Starting
The migration is recorded and the access for the machine is being revoked.
Copying objects
The new bucket is created, and the files are being copied.
Switching to the new bucket
All files are copied and verified, and the machine is being switched to the new bucket.
Deleting the old bucket
The machine uses the new bucket, and the old bucket is being deleted.
Completed
The migration is done, and the machine uses the new bucket.
Failed
The migration was stopped, and the machine still uses the old bucket. The error is shown in the dialog.
If the migration fails before the machine is switched, the machine continues to use the old bucket with all the data, and the new bucket is removed. Check the error in the status dialog, and start the migration again when the cause has been fixed.
If the migration completes, but the old bucket could not be deleted, the dialog shows that the old bucket still counts towards the storage usage. The deletion is retried automatically.
Only one migration can run for a machine at a time.
Deleting storage with object lock
Deleting stored backups from the Storage page works with object lock, but locked files cannot be removed. If any of the files are still locked, the delete fails with a message that the backup data could not be deleted, and the backup registration is kept. Retry the delete when the lock has expired.
Troubleshooting
Message
Cause and solution
The default lock retention must be a positive number of days
The default retention is set to a fixed number of days, but the number is zero or negative. Enter a whole number of days greater than zero.
Object Lock is not enabled for the machine; enable it before migrating its bucket
A migration was started for a machine that does not have object lock enabled. Enable object lock for the organization or the machine first.
The machine has no bucket yet; its bucket is created with Object Lock on first use
The machine has not stored any data yet, so no migration is needed. The bucket is created with the object lock settings when the machine makes the first backup.
The machine's bucket already has Object Lock
The bucket already has object lock, so no migration is needed.
A bucket migration is already running for the machine
Wait for the running migration to complete, and check the progress with Bucket migration status.
The storage for machine ... is being migrated; try again later
A backup or restore was started while the bucket for the machine is being migrated. Wait for the migration to complete, and the backups will continue.
Failed to delete the backup data from storage; the backup registration was kept
Some of the files are still locked. Retry the delete when the lock has expired.
Object lock is enabled for the machine, but the bucket was created without it. Migrate the bucket, or set the machine to not use object lock.
Last updated
Was this helpful?
