> For the complete documentation index, see [llms.txt](https://docs.duplicati.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.duplicati.com/backup-destinations/file-synchronization-providers/onedrive-for-business-destination.md).
# OneDrive For Business Destination
This page describes the OneDrive For Business storage destination
{% hint style="danger" %}
This backend is **deprecated** as Microsoft has shut down the API it was calling. Use the [OneDrive](/backup-destinations/file-synchronization-providers/onedrive-destination.md) backend which uses the Microsoft Graph API and is also compatible with OneDrive for Business. Migrate existing backups to the new backend.
{% endhint %}
Duplicati supports using [Microsoft OneDrive for Business](https://www.microsoft.com/en-us/microsoft-365/onedrive/onedrive-for-business) as a storage destination. Note that Duplicati stores compressed and encrypted volumes on OneDrive and does not store files so they are individually accessible from OneDrive.
<figure><picture><source srcset="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-9a4ec91064cf1a6ff9121bc6d5d4600ad7ad7d5b%2FScreenshot%202025-11-03%20at%2015.16.31.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://2363712449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F7cMJiGuXy340g9NzpxLY%2Fuploads%2Fgit-blob-4a262851f342584fa9dff6a836ce828ae1521c02%2FScreenshot%202025-11-03%20at%2015.16.38.png?alt=media" alt="View of the OneDrive Business configuration page"></picture><figcaption></figcaption></figure>
To use the OneDrive for Business dialog you must enter the server, path on server, account name and access key. You can use the "Add advanced option" button to configure some of the options described below.
## URL format for Commandline
To use OneDrive For Business, use the following URL format:
od4b://<folder>/<subfolder>
  ?auth-username=<username>
  &auth-password=<password>
## Integrated Authentication (Windows only)
If you are on Windows, it may be possible to use the current user's credentials to authenticate. Support for this is depending on many details and is not available in all cases. To use integrated authentication, use the following URL format:
od4b://<folder>/<subfolder>?integrated-authentication=true
## Advanced options
Instead of deleting files directly, they can be moved to the recycle bin by setting the option `--delete-to-recycler.` This gives some additional safety if a version removal was unintended, but is not generally recommended, as it is a manual process to recover from a partial delete.
The options `--web-timeout` and `--chunk-size` can be used to fine-tune performance that matches your setup, but generally it is recommended to keep them at their default values.
If you are running Duplicati in a data center with a very stable connection, you can use the option `--binary-direct-mode` to enable direct transfers for optimal performance.
GET https://docs.duplicati.com/backup-destinations/file-synchronization-providers/onedrive-for-business-destination.md?ask=<question>&goal=<user_goal>
