# Page Not Found
The URL `automation-and-integration/using-remote-management` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
You may be looking for one of the following:
- [Using Duplicati with AI agents (MCP)](https://docs.duplicati.com/automation-and-integration/using-duplicati-with-ai-agents-mcp.md)
- [Using Duplicati to backup OpenClaw](https://docs.duplicati.com/automation-and-integration/using-duplicati-to-backup-openclaw.md)
- [Full-disk backup and restore](https://docs.duplicati.com/automation-and-integration/full-disk-backup-and-restore.md)
- [PostgreSQL backup and restore](https://docs.duplicati.com/automation-and-integration/postgresql-backup-and-restore.md)
- [Google Workspace backup and restore](https://docs.duplicati.com/automation-and-integration/google-workspace-backup-and-restore.md)
## How to find the correct page
If the exact page cannot be found, you can still retrieve the information using the documentation query interface.
### Option 1 — Ask a question (recommended)
GET https://docs.duplicati.com/automation-and-integration/using-duplicati-with-ai-agents-mcp.md?ask=<question>&goal=<user_goal>
### Option 2 — Browse the documentation index
Full index: https://docs.duplicati.com/sitemap.md
Use this to discover valid page paths or navigate the documentation structure.
### Option 3 — Retrieve the full documentation corpus
Full export: https://docs.duplicati.com/llms-full.txt
Use this to access all content at once and perform your own parsing or retrieval. It will be more expensive.
## Tips for requesting documentation
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/automation-and-integration/using-duplicati-with-ai-agents-mcp.md`).
You may also use `Accept: text/markdown` header for content negotiation.
