Using Duplicati to backup OpenClaw
Don't let accidental wipe erase your AI's memory and configurations. Secure your OpenClaw instance with Duplicati’s encrypted, zero-trust backups to keep your sensitive data safe
Configuring Duplicati to back up OpenClaw (formerly known as Moltbot or Clawdbot) is a smart move. Because OpenClaw stores highly sensitive data - including plain-text API keys, session tokens for WhatsApp/Telegram, and long-term memory - it is critical that your backup is encrypted and stored securely.
This guide assumes you have Duplicati installed and OpenClaw running locally.
Step 1: Locate your OpenClaw Data
Before opening Duplicati, you need to know exactly what you are backing up. By default, OpenClaw stores its configuration and "memory" in a hidden directory.
Linux/macOS:
~/.clawdbot(or~/.openclawin newer versions)Windows:
C:\Users\<YourUsername>\.clawdbot
Key files in this folder:
clawdbot.json: Your main config and API keys..bak.Xfiles: Automatic rotating backups (these also contain secrets).memory/: Markdown documents containing the bot's learned context.
Step 2: Create a New Backup Job
Open the Duplicati Web UI.
Click Add backup > Configure a new backup > Next.
General Settings:
Name:
OpenClaw-BackupEncryption: Leave as AES-256 (Built-in).
Passphrase: Crucial. Generate a strong password and save it in a password manager. Since OpenClaw stores keys in cleartext, your backup must be encrypted.
Step 3: Choose a Destination
Duplicati supports dozens of backends. To keep your "AI brain" safe, choose a destination that isn't on the same physical machine:
Cloud Storage: Backblaze B2, Google Drive, or Dropbox.
S3 Compatible: If you use a VPS (like DigitalOcean or AWS).
Local/SSH: A NAS or a second computer on your network.
Remember to test the destination to ensure it is working as expected.
Step 4: Select Source Data
Navigate to the path identified in Step 1.
In the file tree, find your user directory.
Check the box for
.clawdbot(or.openclaw).Filter Rule (Optional): If you are running OpenClaw via Docker and have massive log files, you might want to exclude
*.logto save space.
Step 5: Schedule and Retention
Schedule: Since OpenClaw is an "always-on" assistant, a daily backup is usually sufficient. If you use it for heavy task automation, consider every 6 hours.
Retention: Use Smart backup retention. This keeps one backup for each of the last 7 days, one for each of the last 4 weeks, and one for each of the last 12 months.
Step 6: Finalize and Run
On the last screen (Options), keep the default Remote volume size (50MB). Click Save and then click Run now to start your first backup.
⚠️ A Note on Security
Recent security audits (Jan 2026) have highlighted that OpenClaw stores credentials in cleartext. If your Duplicati destination AND passphrase is compromised, anyone who finds those files has full access to your connected Telegram, WhatsApp, and LLM accounts (OpenAI/Claude). Treat your Duplicati passphrase like the 🔑 to your house.
Last updated
Was this helpful?
